Stock anti roll bars up to the job?
(In Topic #222804)
I bought an ST-branded anti-roll bar kit to retrofit to my 4-door Golf. The car turned out to be a "while I'm in there" kind of project, so the roll bars won't come on for some time.
The thickness of the ST ones are 22mm front and 26mm rear (16,5mm/20,5mm stock), which I have come to understand is more of a racing size. The rear one also connects to the lower shock bolt without any bushes between. I am going to run it on stock suspension, and am more after ride comfort than a sporty and harsh feel really.
So to the point, does anyone have on opinion on the stock anti roll bars - are they really doing anything or are most people replacing them with uprated ones?
Here's the kit I bought: https://www.vwheritage.com/wc411g1001-anti-roll-bar-kit-front-and-rear-vw-spare
Early 77 year model Golf. 4-Door
I never had an issue with my Cabriolets and the standard OEM ones from Factory.
I didn't pay any attention to the thickness when I bought the kit, and from what I read not even newer and twice the weight cars use the thicknesses of the ST ones. Seems it can induce other problems if they are too massive
I'm part rich cash poor atm and the car needs some serious body work.. That's what you get for the while i'm in there mentality
The Lower "K" and upper strut bar by Euro-tune along with the Stock Cabby bars will stiffen the frame very nicely, and with OEM struts front and rear you will have a smooth ride as well as a "Sporty" one…
In my humble opinion.
it went round corners like it was on rails
I'm thinking of purchasing a set to.
Did the set come with the bush mounting brackets? Looks like they're missing in the image.
Cheers.
No I decided to sell them and fit the stock ones instead. The set didn't include the oem brackets, but the polybushes were. Note you don't need the outer rear brackets that slide on (171511433 + 171511453) since it connects to the rear strut bolt instead
Regards
edit here's whats included:
