Excessive pedal travel when braking after installing a 9" Servo & 22mm Master Cylinder to a 1.5 GL.
(In Topic #244385)
I fitted the pressure switches on both the rear brake lines using "T" pieces and a short pipe connections to maintain the original rear brake light operation.
With all the expectations for an improved system, I find that the firm pedal is far to low before effective braking commences, I was hoping for something better than my original system. i.e. touch the pedal to begin braking.
Yes, I can stop, it looks to me that I should not have cut off the 10mm from the 9" servo input shaft.I have googled a bit, it seems that I am not the only one with the issue but I could not find any solution to correct it.I have bled the full system, longest to shortest pipe length, 3 times with a pressure bleeder.
I confirmed the vacuum function of the 9" Servo before and after the upgrade. i.e. Hold the pedal down and start the engine to feel the assistance.
I have checked the rear brakes, no excessive slack, new drums were fitted and worked well with the original servo and master cylinder before this upgrade.
There is a large movement of the brake pedal before any pressure is applied to the front discs (original solid discs still in place). Quite scary.
The brake bar across the car cannot be adjusted at the moment, it is very difficult to undo the nuts in situ. I might have to take it off to free and adjust the connections.
Some thoughts, Are there other 22mm Master Cylinders with different external dimensions?
Is there an air gap internally between the servo internals and the master cylinder input shaft when the brakes are not in use?
If so should I refit the original larger 16V bellcrank connection, plus drill a hole for the heavy duty spring?
Any thoughts and a solution would really be much appreciated.
