Engine swap noob. Procedures, cautions and tips
(In Topic #244176)
Going for a 2-litre "2E" engine-code in my mk1 cabriolet
So now I have the donor in my garage, ready to yank the engine out from it. My plan this far is to do a complete overhaul once it's out. Headgasket, timing belt, clutch kit, cleaning and so on, but his is were I need your help. I recon these particular engines are quite uncommon in the UK, but with the collective knowledge here I might still have loads of useful help.
So what to look for upon teardown? Wich of the two ECUs to use? I've read somewere that the head of the 1,8-engine is better suited for this application. But I can't remeber were or why.
What kind of light tuning mods could be done? I'm thinking mild cam and perhaps a header of sorts? What can you really expect performance wise without swapping the stock ECU?
I'm sure there will be more questions, but I'll start off with these. Cheers from gloomy sweden!
My main concern now is which head to use. Of all the info I've come across, none of it compares the 2H vs the 2E heads.
The choice of head determines which intake to use and Im not sure whether or not the intake of the 2E cleares the inner structure of the engine bay? Both of the engines has 10:1 comp and same size valves.
I've also chosen to go with the 2E pulley/accesories setup, but it seems to stick out farther but does it clear upon installation? (the old 2H engine had a bodged up bracketry)
