Mk1 golf injector seats for dx head thread size ?
(In Topic #241262)
Any help would be greatly appreciated thanks
If so, this particular one's 1.5 (and also 24mm diameter).
Regional Host NE
nicci21paul said
are they not brass ?
I've only seen Phenolic.
There's different plastic caps fit to the brass version to seal the injector hats.
There's also a version that's longer than the one pictured and entirely plastic, sort of halfway house between it and the brass one… seems to have been very short lived, 1984 for a year or thereabouts.
What is the diameter of the threaded part at the top… is it 24mm or 22mm?
24mm inserts should only fit non-shrouded heads whereas the 22mm brass inserts are for shrouded heads only (over and above the injector / ID differences).
Cheers…
