K jet Starting issue
(In Topic #232523)
Car will start and run if I hold air flapopen open
I have refurbed metering head, new pump, fuel lines, etc.
Any idea What to check next. I saw a previous discussion on this but cannot find it.
i
Regional Host NE
wur possible cause
https://www.clubgti.com/forums/index.php?threads/how-to-set-system-wur-fuel-pressure.81658/
compression ok
Sparks ok
any ideas
Control pressure seems too high at 3 bar. System pressure ok just over 5 bar. Will run but revs very high. Drops when u press the throttle. I guess mix is way out.
Can you adjust the control pressure?
