Gti gravity feed tank
(In Topic #211704)
I will be fitting a 1.8t into my Mk1
It was originally a 1.5 carb car
I am planning on just one 044 pump
I have a gti gravity feed tank (heritage non gen)
It's a non baffled tank but does have a swirl chamber and the return line feeds directly to the swirl chamber as well
Can I just add the 044 directly to the tank output or will it struggle to pull enough fuel through
Or will adding a swirl pot from the tank and add the pump after that
I'm really hoping I don't have to add a lift pump as I have already modified my sender unit to work with the mk4 fuel gauge
Cheers all
To help against starvation
