Fueling issue
(In Topic #204429)
Could this be the cause..m
Apologies for re-posting this, I posted the issue in General a few days ago but I have a theory id like to ask opinions…
I'm having a fuelling issue after cleaning my fuel tank out, I have cleaned the gauze filter in the tank and the tank itself, which was full of gunk.
When I start the car now it runs for approx 1 min the struggles for fuel, splutters and stops..
if I leave it for 2 mins switched off, then Re start, it will repeat the above.
I was thinking if this could be a blocked fuel filter, basically the pressurised side of the filter is pushing fuel through at a reduced rate when the car is switched off, and fills the lines which will allow it to run for the 1 min.. Then when the fuel is demanded, it can't pass enough through.
Filter was changed not so long ago, but not since the tank clean.
Thanks in advance
Mike.
It's a 1982 1.8 gti cabriolet with fuel injection.
Has a strapped tank if that makes any difference?
I guess you just have the main fuel pump underneath the car and not a lift pump inside the fuel tank?
Why did you have to clean the fuel tank out?
Was the car standing for a long time or was it a rusty fuel filler neck?
There was a lot of seddement in the tank underneath the gauze filter inside the tank, I managed to get most of it out by pumping and a magnet, I suspect it was the rusty filler neck, which was replaced a few months ago.
The accumulator and the gauze filter in the pump were cleaned to no avail..
There is a guide in the Haynes manual on checking the injectors spray pattern and measuring the amount of fuel which should come out.
There is also a thread in the fuel section on testing the injections which may be helpful.
I'll order a new filter in the morning.
My theory on why it may be the filter as the car runs fine for a minute or so on startup, if it was a blocked metering head / injectors would the performance be bad all the time?
5th injector on the side of the inlet manifold.
I've also checked the injectors and they are all outputting..
replaced the fuel filter, to no avail…. still the car runs one for a minute or 2 then cuts out spluttering…
its very frustrating..
who said owning an old car would be fun
I fitted a new fuel filter too, this improved matters slightly, for a while …. But some times the little "cursed car" just WOULDN'T start no WAY …. From hot or warming up. Narrowed down to certain fueling issues (low pressure ?)
IF I left the car to "cool down" maybe 20 minutes this recent hot weather it would fire immediately … If I could get it back to operating temperature with out stalling I'd be fine for the rest of the journey.
Sometimes I'd start the car from cold and leave it running "just to see" … It would fire instantly settling down to a fast idle (whilst the extra air valve was operating) then as the valve closed the engine began to "hunt" just like my old Escort used to do on a winters morning if I'd left the choke out. Though this was in my instance because of not enough fuel instead of too much. If it stalled during warm up it wouldn't restart until the engine cooled again …..
To cut a very very long story short I have now "adjusted" the "warm up regulator" how to do that is all over the internet … With no pressure gauge I was a little concerned, but with a sick car I thought I'd be really very unlucky to make it WORSE. I started the engine and began listening for the onset of the "hunting" (rough running) miraculously within a few seconds I'd transformed the engine note completely.
Switching off and re-starting is a cinch (just how it should be) and on the road …. ITS A DIFFERENT Car performance is now neck jerking …. ALL DONE WITH A HAMMER ! Regards to the Forum
