5th injector wiring problems??
(In Topic #207188)
Last edit: by BrainsOnFire78
The 5th injector will only operate if I connect a lead from the Green/White connector on the thermo time switch direct to earth. I have so far replaced the fuel pump relay, the 5th injector, the thermotime switch.
Both pins on the thermo time switch are earthing ok but when i connect the plug the 5th injector doesnt work.
I have put a jump lead over the TTS plug and still the 5th injector wont operate.
Any advice appreciated.
