Help
1987 gti cabriolet
hi does anyone know what this part number 24 is called, or where I can get one , many thanks image.png
Anyone help
FYI
rubjonny
FYI ?
What engine is it off as I've never seen one. And didn't have it in my engine
Terrywoo1973 said
FYI ?
The FYI means that if no one comes up with the answer first than John (rubjonny) might know.
vacuum connection for the air shrouded injectyor system. if its snapped block it off to stop an air leak and carry on.
part number is 049103499G, NLA from VW unfortunatly.
Cheers John!   :thumbs:
Thanks John it's already sealed off but my car running very rough and trying to get to the bottom of it
check all the kjet basics as per this thread, ignore the 16v specific parts:
VW Golf MK2 Owners Club • View topic - HOW TO: Tune your MK2/Corrado 1.8 16v
check timing markers as per this thread but ignore all the setup procedures:
VW Golf MK2 Owners Club • View topic - HOW TO: Tune your Digifant GTI 8v
fior ignition timing this is done at idle with vac line to distributor disconnected and plugged, co is done with the car sat at idle, no connectors to unplug but the breather parts apply if the oil is heavily contaminated
Hi bud.. you may have to source a new part from the States or elsewhere… then you got freightcarrier charges & the good ol' government Duty/VAT import charge to consider too…
tryConnecting Pipe
VOLKSWAGEN 90 GOLF Crankcase Breather Connecting Pipe | ALT-049103499G | Best Auto Parts Canada - Cheap Auto Parts Online – Canadian Auto Parts | MTL-AutoParts
also try www.fcpeuro.com & see of they can source one for you. Good luck…:thumbs:p.s. rubjonny is a VWlegend:cool:
