Temp gauge guru needed
(In Topic #224383)
Temp gauge sits at 3/4
as soon as i switch the ignition on my temp gauge goes to 3/4 and then stays there. If i start the engine and get it up to temp the gauge goes to full and over heats. Warning flasher. It's like the gauge starts at 3/4. I have checked the sensors and bought a new one. So hopefully I can rule that out. It feels like a bad earth or something sending a signal to the gauge for it to read like that.
if anyone could help it would be greatly appreciated if i have missed some information out let me know
1984 VW LT31 Camper Taffy ( unfortunately Sold)
1987 vw golf mk1 (Unknown name yet possibly bunny or Virginias Wetspot) not decided yet. Sold
1989 VW mk1 caddy 1989 aaz
The Heights of your technology.
are the pits of my doom
What does it show if sender unplugged?
Whip
/wip/
Noun - Car
/wip/
Noun - Car
thanks for quick replys btw guys
the_whip said
Have you checked the voltage coming from the 10V regulator?
I think you got it there. I found some posts about the regulator so will check voltages tomorrow. It threw me as the other gauges work fine.
Briano1234 said
look in the archive section or click on the link in my signature… there is a wealth of information on flakey water temp gauges, and how to fix, and diagnose them even with pictures.
Hi Briano
Yes I have seen them thanks very good guides
If you unplug your sender on the head what does the gauge do when you turn the car on?
I would suspect the sender or the low/level control circuit before I suspect the gauge… If you unplug the sender, and it stays at 3/4 then I would unplug the low/level controller and see what happens.
I mean the usual condition of the Gauge is that it sporadically works or it doesn't. That is from usually cold solder joints on the wires that are off the studs where it draws power.
I know I can check the wiring on my 90's from the 2 prong connector (yours should have but one lead) using a 9V DC battery (ignition off) and I can power the gauge to go 3/4 to full scale and if the gauge is flakey then I will see it go to low after about 2-3 minutes of battery….
So having it go 3/4 is like the sender or the low level controller is having issues. I would check the input to the cluster pin 4 yellow/red to see if there is voltage there with the cluster powered prior to ripping the gauge apart…. as that would tell me that the Sender or the controller is iffy….. Yes I have had senders go, and rarely have I seen the controller go iffy….but I suppose it could happen.
