no oil pressure light
(In Topic #184145)
I obviously don't want to start it until I know that I have oil pressure.
I have 12v at the switch and 12v at the blue and black wire on the dash connector but don't have a light when the switch is earthed or not.
Any ideas?
I assume that it should earth through the switch when there is no oil pressure and give 12v when there is?
If not should it be earthing through the bulb, in which case which colour wire is that?
I have ignition and handbrake lights.
Thanks in advance.
Simon
These sensors work in conjunction with each other, as well as picking up the engine speed and whether the engine is running or not to decide whether or not to illuminate the oil light, it's not simply earthed through the light as it might be on most other cars.
Mike.
1983 White cabriolet GTi
Is this correct?
It's the little yellow oil pressure LED, which I believe is the standard one that currently doesn't work.
http://www.demonracing.co.za/profiles/blogs/troubleshooting-the-dreaded-buzzer-sound-in-a-mk1
The basic operation goes something like.
Ignition on but engine not running - light flashes as a 'test' but only if connected to the primary oil pressure sender which is a normally CLOSED circuit.
Engine running at IDLE, light goes off if primary oil pressure sender is OPEN (i.e not earthed) If it is still CLOSED then light stays on AND the buzzer sounds.
Engine running above 2000RPM light stays off if primary oil pressure sender is OPEN and secondary oil pressure sender is CLOSED as the secondary oil pressure sender is a normally open circuit I believe (thus disconnecting the secondary sensor usually makes no difference to the operation of the circuit, it just removes the secondary level of protection)
I've just had to replace the little logic circuit in my clocks as it totally failed and started sounding the buzzer all the time, even without the engine running, this is the circuit that controls it all.
It's hidden behind the speedometer.
Mike.
I don't see any change in behaviour if I earth it though. I assume that the logic circuit/buzzer is fused, if so where?
It must know that the engine is running? Presumably this is a signal from the coil or the TCI?
Are these still available or did you have to repair the circuit?
And finally (sorry for the questions) do you know of a circuit diagram or debug procedure to check that I have the right voltages on the right wires going in and out of the dash?
I brought a second hand set of clocks off e-bay and chanced that the circuit would be OK on them and it was, it's a pain to get to thou as you have to strip down the entire cluster.
If you get a multimeter and test between the +12v on the battery and the output on the primary sensor you should see +12v with the engine off and 0v with the engine on, i.e the switch is closed with the engine off and open with the engine on, this is the normal operation of the switch as far as I can remember.
I forgot to check that your engine has the same switches as mine, mine is a single wire switch, but there are variations which have two wires I believe and work as a proper switch rather than switching the terminal to ground.
basically it works like this, if oil pressure drops below 0.3bar and revs are below 1.8krpm (or whatever the high pressure circuit changeover is) then the light will flash. over that the light will flash and buzzer will sound if the oil pressure drops bellow 1.8bar
the reason the light flashes with ignition on is simply because the oil pressure is below 0.3bar, as funnily enough the oil pump doesn't produce any oil pressure when the engine is not turning over
does everything else on the dash work with the ignition on such as fuel gauge, mfa, coolant & battery warning light etc?
First thing to do is to test that the primary pressure switch works!
S
if the clocks have the MFA the main earth is to the side of the head, look for a brown/white with a ring terminal.
also make sure the gearbox earth is good, if you suspect engine earth put a jump lead between the battery -ve and the engien block somewhere that'll rule it in or out straight away
on later mk2s and mk3 the engien earth is moved to a stud on the rearmost engine -> gearbox bolt which is much better. if you have a decent scrap yard local i would pinch all the battery and alternator cables from mk3 1.8-2.0 as they're better design and thicker. you'll have to make up a lead from the chassis leg tho as the mk3 oner wont reach. all i did was get 2 mk3 -ve cables and chop the 2nmd one down so i had 2 ring ends, ran 1 to chassis leg and bolted the other to the 1st mk3 cable where the middle ring is if that makes sense
Simon
Earthing the oil pressure switch doesn't make any lights come on the dash. Is the oil pressure light fused at all?
Also, while cleaning up the earths I unearthed (sic) an unconnected 2 pin connector going into the loom under the expansion tank. One wire is brown, so presumably an earth, the other what looks like white when cleaned up. It's one of the clear plastic 2 spade connectors with the two spades at right angles and is obviously original. I can't see anything to connect it to though.
I love old cars, the more you look at the more you find that has been bodged and badly maintained! I keep thinking I must have found most of it on this one but keep finding more!
That 2 pin connector under the header tank, I wouldn't worry about as my car has the same. It's for an option which wasn't fitted, but the wiring is present for. I've often wondered exactly what it would be used for thou.
Last edit: by Maniac
