Fuse box issues in my 81 1.1 golf
(In Topic #220920)
Sorting the extra wire issues that i had in my other post and i notice a wire that had power suddenly didnt so i checked my fuse box and things dont look correct.
This plug isnt plugged in, should it be.
These look a bit iffy.
There is a white and white/purple wire thats just been cut off.
Does anyone know if these are the correct relays as the wipers are slow and dont park
Also what is this thing.
Help as usual much appreciated.
1989 helio\'s blue clipper
From what I have worked out from John's excellent fuse box diagrams is the front lights (white wire), points power (purple/white wire) and horn (black/yellow wire) have been cut/disconnected and there is a horn on the front of the car with a brown wire vaguely attached to it but nothing else. Why would these be cut they aren't connected in some way are they.
I have also removed the masking tape off the pins/connectors and another wire has been cut. I havent taken a picture yet but it's this one here and its yellow/white and I cannot find out what this powers as Johns ceramic fuse box diagram doesnt put the colours on those particular pins/connectors and people like me need it in very very simple child diagrams.
Its a bit unclear but the reason the G spades have no wire colours is they usually dont have any wires connected, it depends on the options installed. the list is just to tell you what the feeds do
so spade 2 is live when front washers jets are on, if you have headlight washers the relay for this would be plugged in here for example
Thanks for the reply
Yeah I'm not sure at all about the 30 thing. Its attached to something, so I dare not cut it, I will try and trace it back first, maybe someone was trying to wire something in the lights, hence the headlight wire being cut and that joined to the fog light socket
So the tags/pins on G are sort of auxiliary pins, I think that nearly all of them have a plug on them.
I think i am going to have to take the dash out and sort what's what. Gives me a serious back/neck ache crouched under the dash.
I printed out your ceramic fuse box guide and have a copy in the car, seriously good info that.
From my previous thread I have a new master cylinder (NOS) but it has 3 tags on the brake light switch instead of 2. Do you know which tags I use.
Also I asked about engine identification and you said give me the distributor code.
Its 0 237 021 041
030 905 205 B
Thanks again John.
030905205B -> L -> Q distributor is listed for MK2 Golf & Polo 1.05L HZ code engine
I found a code on the cylinder head which told me it's a mk2 golf/polo engine seems a strange engine swap to me, alot of work for no gain and its lost its its originality. A bit annoying if I'm honest.
Anyone got a 1981 1.1 MK1 engine I can have.
View topic: Fuze box wiring layout . Relay locations . Fuze locations . - The Mk1 Golf Owners Club
Thanks for the suggestion, much appreciated.
