AGU lambda problem.
(In Topic #170407)
Basically with ignition on reads .450 v as it should
car running up to temperature the lambda does not oscilate between 0.1 - 0.8 it just reads any where between 0 and .2 v
when you rev the car up it goes as high as .2 that is it.
but when you disconnect air mass it works better and works within its tolerences ????????
i have fitted new lambda twice and replaced air mass.
i have code read it and the only other culprit is the coolant temp sensor but this was replaced with a genuine one a year ago.
sorry if this sounds a little vague just wanted to know what influence lambda voltage in this respect.
i have checked continuety between ecu and lambda - lives and earths etc. many thanks
Website Manager
I take it that you have a narrow band sensor fitted?
It will not give an accurate reading until it reaches about 300 degrees C.
0.5V is lambda ie 14.7 to 1 air/fuel and the sensor will only read from 14.3/1 to 15.1/1 at 0.8v and 0.2v respectively.
how will i know if its narrow or wide band. it used to fluctuate between 0.1 - 0.8 before …………
