Paddling ... not driving!
(In Topic #201783)
Water leaking into the driver's foot well. Not the usual suspects.
Now I've checked the previous threads and I think I've gone throught the usual suspects:
- I've checked the drainage holes at either end of the scuttle and they're clear.
- I've put sealant between the screen and glass (original rubber and glass)
- The plastic sheet is on the driver's side door and sealed.
- It's a non-sunroof model!
I've put paper under the pedals and it seems to be dripping in from directly above - it's not running down the bulkhead behind the pedals.
The only things I can think of is:
- I haven't sealed the screen sufficiently well? (but it's coming in as badly as it's ever done, so it should have had some effect!?)
- The water is draining well down through the scuttle hole and onto the back of the bulkhead - is there a hole/grommet where it could be coming in?
Help! I've wasted a bit of time searching for the leak and I'm not getting enough dry weather to get the car dried out and then test/. It just floods!
Member 125 - 2005
On the drive
Myvalver 89 GTi Grey mk2 16v
