Monti MBX Bristle blaster for removing underseal
(In Topic #223389)
Anyone used it?
Does anyone here have any experience with this Bristle blaster for removing underseal? I am considering to buy an electric version, but the lack of user experience on the web is a bit of a red flag.
If it works nearly as good as on youtube it'd be worth it to me, and they seem to hold their resale value quite high as well. But again very little info on the web, apart from biased sellers
Early 77 year model Golf. 4-Door
Ok it was really a book shelf that they wanted to look like a tree, 45 different sections of wood, cut a various angles, and well over 200 pocket screws that were doweled over…..
Final version
Original before final assembly
Decided that the original could be an issue for my grandaughter and well toddler climbing.
For those that want to know it is Bolted to the wall with 2 13 inch Wood Bolts and 2 10 inch wood bolts, the sections are tied together with Biscuits and Dowels as well as metal strips at the rear supporting the limbs and the trunk…. I was surprised that it actually stood fully balanced and level on the floor.
It cut the wood really well, but can get out of hand if you don't keep ahead of your work, and if you loosen your grip. I did have to fill in some areas with wood putty when it got out of hand…
