Series 1 1.6 FP engine options
(In Topic #193501)
Weighting up my options
I've been reading up on here the last couple of nights about different engine options and what is available. I've got a '77 Mk1 GLS with a four speed box. I'm using it everyday and its been brilliant but it is tragic on anything about 45mph and I'd like something with a little more go in it.
I think its got an FP engine code, which is a 1.6 8v lump. Is there a block that is interchangable like the GTI? Could I just drop the block and put a 2.0 8v from a mk3 golf in it and run it on the current carb or would fueling become an issue?
Any help would be appreciated, I'm not looking to invest in anything turbo/super charged yet as the body work is coming first, but something to help the old girl along abit would be nice. Also I'll drop a 5 speed in when I do this.
Any help is greatly appreciated, thank you
Lee H '77 GLS, 5 door, bronze // Trek X-Caliber 5
The reason I say this is I have a 1978 Mk1 Scirocco with a FR engine in (85bhp from new) and I find it OK to drive and it will keep up with modern traffic no problems, I have fitted a 5 speed box, a webber carb, K&N panel air filter and electronic ignition.
I think you can fit a 2.0l Mk3 golf block but need to check with one as some are taller than others, but not 100% sure if your head will just bolt on.
Link to info about engine codes and output.
http://www.clubvw.org.au/vwengines
Day 1 I removed the "rubbish" I'd built up in the boot, BBS, tools etc….
Day 2 I gave it a good service, amazing what a set of leads and sparks will do.
Thank you mark1gls I'll check the timing etc next week when I pop the bonnet again. Could really do with the 5th gear, are all big block gear boxes interchangable? The 4+E specifically.
You will need to get the gear linkage as well as it's a slightly different set up on the 5 speed boxes, I think there is a guide on this type of swop on here.
I had a 4+e gearbox on my Mk1 Scirocco for a short time but did find the car had no go in 5th but at 70 mph the revs was at 2000 rpm so relaxing on the motorway but had to drop to 4th on any big hills. I changed back to a normal 5 speed as I don't do a lot of motorways but at 70 mph the revs are now at 3500rpm.
http://brokevw.com/
Thank you, I'm now looking in to getting the parts together.
Sent from my SM-G981B using Tapatalk
Lee H said
Thank you, turns out its been getting progressively more spritely everyday.
I have noticed over the years that Cars always work a tad better after a service or the week before I trade it in on a new one.
lewisharvey464 said
Do you know the code for the 4+e gearbox
4T is a 4 speed and economy 5th gear
