Why wont my mk1 start?
(In Topic #72986)
i did about 60 miles in it and then it stopped working, was driving perfectly and then simply stopped, my friend, who mighth as well be a mechanic, thought it was the distributor cap, so that along with the rotor arm was replaced - no. which means i'm kind of out of idea's.
we know:
it's turning over
it's getting fuel
it's all sparking at the distributor
all pedals are doing what they should
the car was sitting idle for 4 months prior to me having it.
i filled it with petrol the day before it died (and yes it is petrol and not diesel - when we ran out of idea's we checked) it's unleaded as i've read in a number of places that no water cooled VW has ever needed leaded petrol.
Any suggestions would be very much appreciated.
You say you've checked the spark at the dizzy, have you checked it at the spark plug ends? Also you're sure fuel is getting through the carb? Would also check points and condensor, pitted points can prevent starting. New points and condensor only cost ?4 or so each. Also check the cambelt is still all in one piece 8O .
1983 1100 C
1983 1100 C
when i turn the key the starter motor works perfectly, so it's not that. the car has sounded like it tried to start a couple of times, but only like 1 combustion or so.
i haven't been able to check the ht leads at the other end, as unfortunatly they're heat shielded ones, which don't allow you to simply arc it across the block. although i doubt its that as it was working perfectly then stopped - so the chances of all 4 going at the same time are , i guess, minimal.
as for checking points etc, i will have to get my friend (mechanic) to have another look, although i'm sure he would have checked that - he certainly said it was getting plenty of fuel.
this is really annoying, as my other car drinks petrol, so getting my mk1 on the road again will hopefully save me about ?40 a month in petrol, wich could be much better spent on buying some shiny bits for the golf.
only test still to be carried out is compression test, which i'm really not looking forward to, as it could confirm worst fears, esp as the car was smoking a little when i first got it - assumed it was simply because it had sat idle for a few months, as it stopped after 30 miles.
now looking at cheap mk2 gti's, as i need a new interior, alloys, and now an engine so if i can pick up a mk2 for ?300 or so it'd be worth it, and i can drive it while getting the mk1 ready.
does anyone know of a good tutorial for dropping a mk2 gti engine into a mk1 1100 shell?
cheers.
However this may have been deemed irrelevant by a woman in a passat who thought she could park on my nearside, so will have to wait and see what hapens - maybe this'll work so i can buy a gti straight off.
still at least i was hit by another vw.
