Oil Pressure Switch
(In Topic #147747)
Oil Pressure Switch
Replaced my oil pressure switch for the dash warning light yesterday as the one i had was leaking everywhere. I got one from Euro Car Parts but the warning light doesn't illuminate when the ignition is switched on, but illuminates when the engines started and then stays on all the time. It also keeps the Handbrake warning light on at the same time for some reason?? Any ideas ??
Indidently its the sender at the top just behind the dizzy, the old one had a black barrel, the new one is a white colour and it has a blue wire connecting onto it.
when i done mine there was two, i put the wrong rated on in the wrong place, causing the light not to flash when the ignition was on.
pic for some reference (ignore the chocolate blocks they long gone)
Not sure how its effecting the hand brake light? Note this is also the brake fluid warning too. Is there plenty of fluid in reservior? Did you knock the wiring on the cap when fixing the oil switch?
bucket said
how many pressure switches have you got on the back of the block? which year car?
Thanks for the responses fellas,
Mine seems different to yours looking at the photo, i only have one sender unit on my block (Same place as the one on the right in your photo)
I checked the Brake Reservoir as a precaution, and all is fine, but when the engin es running, if you earth out the blue sender wire on the block the oil light and brake light come on together (With the handbrake off) :dontknow:
the genuine vw white ones are 1.8 bar and blue/brown are 0.3 bar. dont go by the colour if pattern as they can be anything. oh, and i wouldnt buy pattern rubbish either, genuine vw ones are cheap!
Asavar Kul said
Hi Is the high pressure switch above the oil filter and the low at the front of the head?
Yes high pressure sensor above the oil filter and the low pressure sensor is on the side of the head above the gearbox.
