Is my engine going to die?
(In Topic #135142)
Am i losing compression due to worn piston rings of is the headgasket on its way out or something like that?
this is the first week the car is on the road in about a year. :cry:
any help will be apperciated
A compression test would reveal.
If you can't get the idle speed down, its likely a carb fault, not an engine fault. Do them things have a coarse throttle adjustment?
Head gasket failure - once again, compression test is needed to prove this. One way of determining if a cylinder isn't working (if its blown the head gasket between cylinders, then an adjacent pair won't work) is to pull off ignition leads while its running. No change on engine note/revs means that cylinder wasn't firing. But that can be due to other things than head gasket.
