Gasket sealant
I'm replacing gaskets on rocker cover, exhaust manifold and exhaust down pipe.
Should I use any sealant, if so what is recommended?
Thanks in advance.
Sent from my SM-G955U1 using Tapatalk
Gasket sealant
I didn't use any on the rocker cover mate but i swapped it from cork to rubber gasket and its been good no leaks i just made sure it was mega clean and nipped up the rocker cover nuts after a couple of hundred miles or so
Sent from my SM-T585 using Tapatalk
Gasket sealant
Thanks. I couldn't find a rubber gasket for a 1.1 so ordered a cork one. I think there is a topic somewhere with recommended torque to tighten bolts up to, so will find that next.
No sealant on the exhaust manifold?
Gasket sealant
Ok mate i wasent sure what size engine you had ,i had my stainless steel exhaust manifold fitted by a garage as i couldn't get the rusty studs of the old one so i dont actually know mate sorry
The torque on the Valve cover nuts are 87 in/lbs.
No sealant on the Gasket, but you can use one drop of sealant on the cam over seal meets the cork gasket each side.
