backfire at 3000-4000rpm
(In Topic #130025)
Check the vac advance is working - you can do this just by sucking on it and see of the arm moves
Other things I'd check:
Coil
Carb shut off valve is working correctly and opening properly
Fuel pump is delivering sufficient fuel - could be the pump or the pick up in the tank. Also have seen perished rubber hoses at the tank sucking some air
You could also try spraying in some easy start when its missing to proove if it's fuel or an ignition issue.
Rich
