1.3 overheating problem ??
Rite where do i start i got the car a couple of months back and it was overheating rite from the start i did the obvious like thermostat flush the rad out temp sensor and still it overheats so i took the head of to se the block was cracked so i buy a block and did the headgasket new head bolts the head didnt need skimming  so thats fine put it all back together and it still  overheats can anyone help me thanks
What makes you think it's overheating ?
check that the ignition timing isn't too far advanced, and check that both pulleys line up to TDC properly, misaligned pulleys will lead to the combustion happening at the wrong time.
1983 Golf 1.3 Driver:
