1.3 GF engine Main bearing concerns
(In Topic #220133)
Please help identify parts
Hi all,
I have an issue finding the right main bearings for my engine.
I have a 1272cc GF engine, the bearings that are fitted all have 360° oil grooves, number 3 bearing has thrust washers fitted.
The issue I'm having is that the part numbers I can find for the bearings are showing number 3 bearing to be flanged and not have thrust washers. I contacted a company to try and source the correct ones and they have come back to me with a set of bearings that are the correct size and without a flange but only 1 pair have 360° oil grooves, the other 4 pairs have 180° grooves. The kit says just number 4 bearing has 360° groove but mine has it on all 5.
I would like to know if anyone can help me source the correct parts, standard size, or convince me that the 180° oil groove bearings will be OK to fit.
I've not had a look at my engine to see if there are oil galleries on both sides of the bearing housing so I guess I need to do that.
I hope someone can help me out. I'm ready to purchase them and get the crank back in.
Cheers,
Britney.
Goly The Golf, a 1983 5dr 1.3cl having a full resto.
Number 27 and 28 on the diagram was the first issue, they are the flanged number 3 bearings but mine have no flange but thrust washers instead.
The second was the oil grooves.
I will pop to an engine builders when I get a spare minute, I think there is a good one near me in Kegworth, SEP, so I'll see what they have to say.
Thanks for your reply. 👍
So I suspect it depends on the manufacture of the part as to what you get. That is a 2H engine.
Thank you for your replys 😁
After a few long months of searching I have managed to find the correct bearings.
These sets have 5 pairs of bearings with the 360° oil hole I need.
Time to get them ordered and the engine built.
Mahle : 029 HS 10038
King : MB5028AM
Kolbenschmidt : 87420600
Cheers 🤘
