REAR BRAKE ADJUSTMENT?????? HELP PLEASE
(In Topic #123896)
Is there another way of adjusting ive taken drum off but cant see an adjuster
Thankyou
basically as you use the brakes the wedge is pulled down by a spring and holds the shoes at the correct tension. You should be able to see a big metal plate between the shoes and a spring going vertically down onto the bottom of the leading shoe. it's that spring that is attached to the wedge. if the wedge is right down against big late then they are at max and need replacing. mine were when i had them apart at the weekend.
to adjust them i usually wedge the shoes apart and slide the wedge up to slacken them off. then put the drums back on (remembering to adjust the wheel bearing until it's just thight enough to allow you to nudge the washer across,) and pump the brake pedal a few times. pop back out and spin the drum, you should feel the leading shoe scuff slightly. that means the shoes are where they should be. the rest is as dwgolf has said!
Jon.
Ill follow that
Many thanks
