PLEASE HELP? gear stick fallen through gator
(In Topic #76519)
new member looking for some help.
recently bought a mk1 gti needing tlc. Main problem is to do with the selector i have been told. Basicly the gearstick has dropped down through the gator, gears can be selected but with difficulty (if you jiggle the gearstick enough you can find the gear) Can anyone help me with this problem, is it a selector problem? what needs to be done if it is? what else could it be?
Thanks Igloo2000 :dontknow: :dontknow:
I guess this has popped out allowing you to push the gear stick down through the spring.
You can clip it back in but it may well go again so worth buying a new one for pennies from VW and fitting it! (Get circlip pliers to for ease!!!)
Also check under the car. If you have pushed the stick right down, you will have probably poppoed out a plastic disc which sits in the rubber boot underneath the stick under the car. IF you don't replace it you'll get all sorts of crub/water finding its way in.
I talk from experience - and was lucky that my plastic disc fell out on my drive!!
May be worth checking all of the gear linkage too in case worn
Life Member
PLEASE HELP? Problems with gear sloppy gear stick.... still!
please help if u can make sense of my jibberish, thanks matt :dontknow:
1983 1100 C
1983 1100 C
