Lowering Springs
(In Topic #72960)
Lowering Springs
Am i daft to not change the dampers at the same time?
Whats the verdict on angle-grinding 50mm off my current springs. Anyone done this with success, do your wheels foul the arches and do you get grounding etc?
'83 Mars Red 1.1 C
Mk1 VW Golf 'c' restoration job....
The harsh ride is because most factory springs are slightly thicker (harder) in the middle coils, and slightly thinner (softer) at the top and bottom coils. If you remove the end of the spring, you are left with a "harsher" spring.
If you want a lower, firmer ride, there is no substitute for buying (at least) reasonable quality springs, I'm afraid…
There's no reason to change the dampers, if you're on a budget, but having lower springs on damper that are worn-in with higher ones may cause them to fail a bit sooner than they otherwise would have. You might be lucky, and this won't happen, but if it does, there is a lot of work in changing them - Place your bets…
PS: If you want better handling, and aren't worried about the ride height too much, you should try to get the anti-roll bars (and mounting brackets) from a Mk1 GTI. They fit straight on with just a few simple holes drilled in your (non-GTI) wishbones, and the car goes around corners much better, with much less body-roll.
the anti-roll bar is something i'm trying hard to find. I'm chasing up one lead at the moment. I'm sure its going to make a big difference, but i'd like to drop the car for cosmetic reasons too.
'83 Mars Red 1.1 C
Greg said
Is it possible to take the springs out without changing the geom too much - or is that impossible?
Unfortunately the Mk1 is from a design-era where opening any bolt on the front suspension means that the camber and tracking settings are lost. You can try marking nut/bolt/component positions, but if you don't get it accurately checked afterwards anyway, you might find out that you got it wrong the hard way: when you notice that you've made your front tyres bald on one edge…
Still, the Golf had moved on from earlier cars which had maintenance issues like weld-on front wings (60's Mercedes) and suspension/steering components that snapped, resulting in the wheel and hub falling off, if not regularly greased (the "trunnions" on Morris Minors)
T17 - i kinda thought as much. I guess i'll mark with paint - i've had success doing this with an audi coupe in the past. Also, i think i know a place that does a free camber/tracking check not far from work.
Welded on wings?!! jeez what were they thinking when they designed those? Wasnt mechano around in those days to learn from?!
Does that mean the 280SL (gullwing) had welded on front wings?
'83 Mars Red 1.1 C
Life Member
