Golf 1980 1.1 drive shaft keeps popping out!!
(In Topic #148480)
Any ideas???
Drive shaft popping out
1- Drive shaft is bent, therefore not fitting securely into CV
2- Suspension leg or hub is out of line.
3- mountings could be work, hence causing play to alignment of GBox
For it to pop out as you have described there has to be something visibly wrong.
Check your wishbone and ball joints etc.
Birmingham
Thanks for the reply
