cr*p brakes UPDATE MONDAY
(In Topic #94809)
i swapped my rear shoes after i did an axel swap
left the fronts as the pads were kl
bled the brakes with a bleeding kit, the type you use a spare wheel to give you the pressure
now my brakes are rubbish! pedal has nothing and it does not return normally
one bleed nipple was snapped off by the previous owner, going to get a new one (rear)
i did not bleed the snapped nipple obviously
so my question is will my brakes drastically improve once i fix the sheared nipple anhd bleed it
or have i got a bigger problem
shit! would describe them currently
blled kit which uses a spare tyre, for pressure?
bottle of brake fluid, tube to the servo with correct size cap
another tube off that to the valve of a spare wheel
creates a pressure system
as you open the bleed nipple the pressure from the tyre forces the fluid through the system
when you see no more air bubbles close the bleed nipple.
no need for pedal pushing or two people etc
there was a fluid leak but i sorted that( rigid to flexi not tight enough), improved the pedal but i still think i have air the system.
i asked this question as i dont think a massive improvement will come from sorting the remaining bleed nipple!
and one got any ideads
Also, auto adjusters often don't adjust the pads up to the drums properly, this gives a long brake pedal travel.
paul_c said
Yeah the Easibleed kit uses air pressure from a car tyre. If you have swapped the axle but omitted to bleed one of the rears, then it will have loads of air in and give you the symptoms. So you need to sort this out and then bleed. Personally, I never use the Easibleed (used to), because the pressure compensator and possibly non return valves, mean it bleeds the rears too slow. And I know that MC seals can fail using the one-way valve technique, but I'd rather it fail in the workshop than on the road!
how do i tell if the mc seal has failed
by the sounds of it i still have loads of air in the system, i have another go after i sort the broken nipple
cheers guys
try never adjusts the shoes. that'll be a bit nearer the truth.
I'm kinda trusting VW that they work when they're brand new, otherwise they'd have never designed and used the system!
best and easy way to adjusted them is to look through the bolt hole with a torch and a flat head,lever down on the tapered adjustedment untill the shoes hit the drums and your sweet! saves taking the drum off!!!
also dont use a easy bleed kit!!!
get you mate or you women to jump in and pump the pedal!!!
best way to bleed the brakes, is to pump the pedal 10 time hold pressure let the nipple of, let all the fluild out thenlock the nipple back.repeat process untill you feel a good pedal!!!
also try bleeding from the master first!! and work your way back!!!!
if not your master has had it!!
i have swaped both the rear cylinders for new ones
and bled the brakes again and fully adjusted the rear shoes
my brakes and very good now!
HOWEVER
i have a leak i think
either coming from the rigid to flexi line on the passenger side, in that really shit place by the rear axel
or that slave unit (think thats what its called) near the same join, the thing with the spring that comes off from the axel
hope you get what i mean!
how can i solve the leak from either of these places?
i have tightened all the bolts as much as possible?
can overfilling the system force leaks
because the fluid is a little bit above max!
you maybe looking at new lines if ones now gon a bit iffy
could this be the problem
would i have to remove the axel again to change it?
are there new brake lines avaliable or do i have to make them?
is it more likely to be the rigid line or the flexi?
how safe is it to drive like this? im not going to, just thought i would ask
the leak is drips, no running out! wet can be seen though after a while
change the flexi and the soild to be sure.
making a set is not that hard and the tools are reletively cheap these days.
yes you will have to remove the rear axle again. sorry.
dam it, for the axel removal, so scared i am going to brake another bolt
shouldnt do though as its only just gone back on!
to swap the rigid line that runs along my axel?
without damaging or destroying anything ?
