4 t0 5 speed converison
has anyone ever done this ive got the 5 speed box but need to knopw if all the linkages are the same or diferent
What type of 5spd?
And by 4spd, do you mean early 1600 gti 4spd or 1300 Driver 4spd?
from a 4 +e from my 1976 1.6 ls to a 1.6 gti 5 speed box :lol:
4 + E? Should be a 4-speed originally  :?
Sounds like someone before you already made the upgrade to a 5-speed in which case there should not be a problem!
4+E
I used to run 4+e gearbox`s in my 5 door GX but after breaking 3 of them with the 150-160 bhp i switched to the mk 2 5 speed box ,although i miss the 155mph top end which could be reached the 4+e did have a very nice cruising feel to it . :)
If you got a 4+e as said above, it is basically a 5spd, so the linkages should fit the other five speed box.
Before you even start though you want to check out the codes on the boxes and compare them to these charts:
http://www.nwlink.com/~vdb/vw/Transmission/speed-ratio.html
VW 020 5-Speed Transaxle Ratio Chart
This will help you work out if the boxes have different ratios or not.
You also need to ask yourself why you want to change. If it is shorter ratios you are after, check out the links above to see which are the short ratio boxes.
Hope they help - they sure helped me!
AL
oh god what a cock up i wrote that in a rush ok
from my 1976 1.6 ls 4 speed
               to
a 4+e or 5 speed mk1 gti box
no i need to change to 5 speed for motorways wanta  longer gear  or it be thrashing its nuts off in 4th wont it on a 4 speed box?
Well I got a 9a (Campaign) box in mine and it is one of the short ratio varieties. I have to say it is not the best for cruising! at 70MPH the car sits between 3500 and 4000 rpm! I do have lower profile tyres than standard which reduces the overall gearing a bit too.
If you want a box for motorway cruising, you want an 1800 Gti 5spd box.
Check the codes of any boxes you find against those links I posted, just to be sure!
yeha ive got a 9a in my valver revs liek hell but next engien is goan be 8v so not as bad the box ive got is a 'fd' code? ratios look pretty similar to the 9a?
