One or may be two from three cabriolets
(In Topic #220816)
Regional Host NE
Last edit: by nicci21paul
Regional Host NE
one of the gti engine and
boxes and change the fuel
supply
Regional Host NE
or are we cutting it out of the blue one
Regional Host NE
Regional Host NE
Regional Host NE
Regional Host NE
Regional Host NE
Regional Host NE
Regional Host NE
Regional Host NE
and pieces throttle cable
clutch cable speedo cable
things are looking rosey
Regional Host NE
accumalator also in tank fuel pump
swirl pot radiator with fan few bits of
pipe work breather and vacuum success
Breaking For Spares no longer
Not sure I would trust that mileage as the numbers don’t seem to line up very well?
If the cars been pushed around without the drive shafts fitted to the hubs it’s worth adding 2 new front wheel bearings to your list as they don’t like being used not under tension.
looks like a good solid cabriolet to start with which is a bonus..
picture of my daily without the front bumper, the drip marks around the holes is all the waxoyl I keep covering the car with.
Last edit: by mark1gls
Regional Host NE
spare stub axles to refurb.
and a couple of spare shafts
to sort as well
Regional Host NE
would cause overheating problems
mate
Regional Host NE
and a fuel metering head with air flow sensor
Regional Host NE
nicci21paul said
do you think the extra hole not there
mate
I would not think it will matter, just make sure you fit a GTi radiator and a water cooled oil cooler. There's plenty of air flow from the grill area and it's not that often we get really hot weather.
