Front seats
(In Topic #229550)
'Recaro' style seats wanted
If you look up on https://volkswagen.7zap.com/en/rdw/golf+cabriolet/goc/1992-44/8/881-184000/
you can see design on seats - you can then look up mk2 with recaros as well.
I've rebuilt a few mk1 cab seats and recaros and I've found that later seats are similar but the meta structures are different = different foam required and then covers.
I did find out that mk1 late cabs 92/93 did have recaro seats the same as mk2 recaro seats and same in mk3 golfs too - again you need to check the base codes.
Hope this helps
Yes there is foam for repairing seats and foam for smoothing and fill out.
This is what I've used - US specs, might be different named in UK, but
Smooth covering: (Pink in color) Fabric Backed 1/2" Sew Foam 58"
Fix seats foam: (white in color) High Density Polyurethane Foam (Extra firm)
It took me ages to figure out the above as people don't like to share this information. Youtuber don't tell you this either…
Last edit: by madone_si
