"TAG" - 1983 Campaign restoration blog
(In Topic #207931)
New wheel bearings, wheel cylinders, drum fittings, anti roll bar bushes/clamps
P.S. Buy yourself a cheap second hand in built oven put it on a bench in the garage.
I also find the dishwasher useful fro a deep clean, I get a few comments with that.
I had two of them before I got rid on them years ago.
Still sell them brand new. Just had a look at ebay.
Use a Magnet on a flexible to removed any debris from the tank.
The fuel filler might have been replaced previously and the system not cleared out.
Use a Magnet on a flexible to remove any debris from the tank.
Good luck.
Apart from the finished photos on page 4 of my project, I only have this from Etka.
You can work it out and see how it all goes together. The issue is that this area gets wet and traps muck.
When I did mine, item 23 was corroded badly, you might be able to recover item 22. And fabricate a new bracket.
I was able to purchase a new gravity valve mounting (13A) from VW, basically a polystyrene type moulding. This could be fabricated out of something similar if unavailable. Your Gravity valve (40) probably just needs a clean and test. Turn it upside down to see that the valve works.
I replaced my attachment nut and bolt with plastic number plate nut and bolt, with a large load spreader washer to keep it all in place.
cdgthreesalmons said
Agreed Malcolm. Looking at the receipts over the years there are plenty of "fuel related" issues including a new set of injectors. I am certain the pipe is a replacement but the rest of the system has not been thoroughly cleaned. Do you any photos of the gravity fuel valve, high up in the rear wing over the fuel filler??? As mentioned mine was "stuck" to the wing due to the bracket rusting away!
