Help please, what engine do i have
(In Topic #223701)
Wondering in any one can help me with identifying my engine and cylinder head
I bought a MK1 campaign and i don't think the engine is original,
the number on the engine is EV074976*
the number on the bottom of the engine is 026 103 021
the number on the head is 026 103 373 H
am i right in understanding this engine is from a early MK2, if so does the cylinder head and block match up to each other? i just get the feeling the engine was thrown together and sold with the car to make it look more complete, the engine was never working when i bought it and most of the parts for the car are missing
I have had the body work and paint done over last year so its time to sort the engine out
thanks for your time
thanks very much
Dale
http://vag-codes.info/files/engines/vw-engines.pdf
I can see the intake is on the left on the EV engine but the DX engine has it to the right
could you tell me what things do i need to bear in mind if i am to fit this engine?
thanks for your help
Early-1800 said
Digipants? I have heard it called many a thing but Digipants….. DIgiFarts…was more common…..especially when it don't work.
Briano1234 said
Is it pretty straight forward to fit
would you know (apartt from a original DX engine )what would it better to fit the 8v or 16v engine?
Depends what you are trying to do. if for more power the standard route these days seems to be a 20v turbo. If to keep it looking basically the same the EV would be fine
sounds straight forward enough,
I'm not after more power i prefer it to be as standard as possible, I have the EV engine and box so i am just wondering if i overhaul it or buy a dx and overhaul that.
If the EV is not to much trouble to fit and its still considered a good choice then i will stick with it. I need to buy everything mechanical apart from the engine anyway so i am trying to weigh up the options
thanks for all your help
