Wheel Spacers
(In Topic #75805)
Wheel Spacers
Ive noticed that my rear wheels arn`t quite in line/parallel with the front ones on my campaign. So i was hoping to push them out to give it the "phat" look to fill out my arches
So i was wondering which size of wheel spacer would be best to get `em to line up—– 5mm or 10mm? Also will i need longer threads to put `em on? And is it an easy job?
Has anyone elso fitted spacers? :dontknow:
Lookin forward to hearing all your opinions….
Stay out of the black…
And into the red….
You get nothing in this game for 2 in a bed!
And into the red….
If you want to increase the rear track then space the stub axles from the beam and get longer bolts to suit.
Didn`t know it prove to be dangerous to space `em out. Where would i get hold of stub axle spacers from; and how much would they set me back?? :dontknow:
taa….
And into the red….
And into the red….
Best bet is to get a local machine shop make some out of certal (sp?) plate the correct thickness. This shouldn't need machining to thickness as the material is already machined to a nominal thickness.
Hope this helps.
