fuel pump issues? intercooler g40 conversion?
(In Topic #74394)
i have got a 1978 mk1 3dr campaign model which i have totally stripped.
I am in the middle of dropping a polo g40 engine in it but i have a few problems i need advice on.
The g40 engine i am putting in the golf in an injection engine, i salvaged the enigne from a wrote of car but could not get the fuel pump. As the crappy original 1.1ltr is single carb i need a new fuel pump. I have come across a mk1 gti fuel pump, will this be alright to run with the g40 engine as i am tuning the engine a little or will i need a g40 pump.
Also with this conversion the g40 intercooler cannot be used as it sits right behind the front crossmember. does anyone know of of a suitable replacement that could possibly sit next to the radiator, a vag intercooler would be preferable.
cheers john
For the intercooler, it depends how much you want to spend, I've seen a nice Rad, intercooler and oil cooler all in 1 peice for about ?650 but if not the merc sprinter van intercooler is used alot.
Graham
(Boraboy on most other forums)
Cabrio GTI Now in Lhasa Green with running 1.8T AJQ on OEM management.
Coming to bits again for more mods after reading to much on here…
Oh yeah, and a Golf V GT TDi
PS: Don't forget that the word Campaign gets mentioned a lot with Mk1 Golfs, but only applies to '84 (some and late '83) GTI models… :wink: :wink:
I will have to think about the rad/intercooler combo as i cannot stretch to 650 quid on such an item.
i will definately have a look around for a merc sprinter unit.
thanks for the help.
what did you do about the driveshafts? i have put the g430 inner cv joints on the golf shafts and kept the golf outer cv's. this is to keep the right track width.
