CLUTCH PEDAL PROBLEMS.......?
(In Topic #138756)
i was wondering if anyone could give a bit advice on a slight problem that i have with re-fitting my clutch pedal…?
I put the pedal back into position with a the retaining clip on the end, with the clutch cable too. However when i press the pedal down there's not alot of resistance and there's no spring return…? i had a look at my mates mk2 golf which is more or less the exact same apart from there's a spring on the pedal allowing it to do what mine cant..? so i thought i was missing a spring that attatched to the pedal..? i can see theres two small bores at the top of the pedal which i havent used…? can this be for a spring…? i looked at the diagram and read the haynes manual, but couldn't see anything about a spring…? any suggestions…?
cheers sean
The car was bought as a project and most of it was dismantled when i recieved it, wondering if theres any parts missing..? but looking at the haynes diagram i cant see anything…?
Website Manager
Can you operate the clutch lever at the gearbox end without any resistance ? If you can then it is likely that the finger on the end of the operating shaft has cracked. The shaft and finger are inside the gearbox, but easily be accessed to check.
