Anyone used an ecotek valve?
(In Topic #73338)
yet if they were as good as they claim to be i was wondering why everyone doesn't use them.
any comments would be much appreciated.
I've been keeping my eye out on ebay for a bargain as the list price seems a little steep to me for such a small and simple valve. However, it does make me wonder, like you say, if they are that good why are so many people getting rid of them on ebay?!!
Xoilac TV - Bóng ?á tr?c ti?p Xoilac m?i nh?t, xem bóng ?á Full HD
my view is that they would create little or no benefit.
I've got a used one if someone wants to have a go and try it out. Yours for ?6.50 incl postage!
It clogs up with oil from the crankcase every few months, and needs cleaning out. (not an issue if your engine is new and unworn, but most Mk1's fall into the worn category)
He reckons that it doesn't make much difference, and points out that where a good accessory is good, and makes a difference, it gets adopted by manufacturers (eg: Hella's Raintronic auto rain sensor is now "built into" many new cars, at all levels, not just prestige models), but where it doesn't make enough difference, it doesn't get adopted (eg: those magnetic "fuel savers" you put onto the fuel lines, or the valve that we're discussing here :wink: )
He reckons that there would be more to be gained from your engine by ensuring that things tlike these are in tip-top condition/adjustment:
Airfilter
Spark plugs
Ignition leads
Distributor cap & rotor arm
Points (if applicable)
Crank/valve timing (if belt-driven)
Accelerator cable (should be adjusted so that "flooring it" actually does equal a fully-open throttle)
Oil level (overfilling causes crank-drag)
Tyre pressures
Holden Rodeo Twin cab 1997
Hyundai Excel Twin Cam 1998
Golf Gti Mk1 Cabriolet 1984
My Build Thread
