Will a 1.8dx metering head work on my 1.6eg?
(In Topic #208837)
Regards Volkswarren
Sweet thanks! I know physically they're the same but thought the 1.6 might run a little less fuel pressure so wasn't sure, I assume it will fot my airbox too?volkswarren said
Yes 👍
Last edit: by MK1CabbyWhite
Regards Volkswarren
I've fitted the 1.8 unit and got the car running at last I'm happy to report, I still have the 1.6 head so could swap that over at some point, is the whole arm different or just the round disc?rubjonny said
if you fit the right late 1.6 air metering flap to match it will be fine, alter 1.6 used same metering head as DX but different flap housing to compensate 049133471H
But yeah, if it drives great then no need to worry about it
