Mk1 golf Warm 1.8 16v PL starting problems but bump start is easy
(In Topic #243712)
If someone give me a push it bump starts very easily.
I just tried a new battery but this has not helped.
Does anyone know what the problem can be?
https://www.volkswagenownersclub.com/threads/brianos-quick-grounds-test.134637/?post_id=765374#post-765374
If it works replace your grounds Battery to frame and frame to engine.
If you want to improve your starter solenoid current flow.
https://www.cabby-info.com/files/ignition/InstallingHot-startRelay.pdf
The starter motor is working normally, the car just won't spark/fire into life.
Pello316 said
I checked the earths and it all seems to be good.
Checking and knowing are the last things and the first things you should check.
Do my Quick test it is easy and may just work.
Bump start and working would suggest that you have a iffy connection or fueling issue.
The purpose of the Quick Ground test is that your adding a new good ground path for the Engine and frame.
Once the jumpers are in place, does the car start fine?
Yes, then replace your battery to frame and frame to engine grounds.
No, then further information is needed. As a 1.8 16v was dropped in to your ride? there where wiring mods?
What fuel type is your ride? Carbed, CIS, Digi?
Does the starter engage, and spin the engine when hot, but the car won't start and engage. Or does the starter fail to spin?
Is it automatic? or Manual Transmission.
The starter motor is working fine but and turning over the engine but just does not start.
There are no additional mods, I have the original ceramic fuse box and the correct wiring loom for the pl engine.
I use normal unleaded fuel and the pl has the cis-e
It's a manual.
I've had other cars where a poor hot start was caused by the ignition coil starting to fail.
When I changed my one cabby to a single pump from a dual, the in-tank pump was noisy, but hearing it hum was a good thing. I just turned the Radio up a bit.
Have you done fuel pressure tests when cold verses warm?
I know I had a digifant 90, that when the Fuel Pressure Regulator went bad there were warm start issues?
The residual pressure tests nailed it.
