'88 Cabby with white smoke
(In Topic #243500)
My cabby is releasing white smoke from the exhaust and intake manifold area. It seems to be leaking oil, smells like it too. She was leaking a little oil when I bought her but not as much as now.
Would love to hear your thoughts and let me know if you need more info cause I probably explained it poorly.
https://streamable.com/k4qne1
https://streamable.com/ce5cdk
https://streamable.com/l1o1wo
Last edit: by sushilover123
If the smoke smells sweet that is a sign of coolant leak, or blown head gasket.
If after running for a few moments, to eliminate the condensation, and it is white smoke then that is usually a sign of a blown head gasket.
Blue or Oily smoke is Oil.
Do the coolant Hoses on your ride get really hard and balloon, as that is another sign of bad head gasket, as well as a oil slick on top of the coolant
another sign that you have a bad head gasket.
White smoke from the exhaust tail pipe is normal for the first few minutes on a cold engine, but heavy white smoke when engine is warm is a sign of head gasket failure - water entering the combustion chamber and coming out of the tailpipe as steam. Usually followed by misfires and/or the engine overheating. And mysterious loss of coolant.
so i took out the cylinder head to see and the head gasket seemed fine, as well as the valve cover gasket.
However the surface seemed to be a little bumpy like this picture(picture on the internet, not mine but showing for reference). Maybe it is contributing to it? prob not. idk
So i replaced it and put it back together but still having the same problem.
In terms of the coolant level, it is dropping but i think its leaking from the heat core cause i can smell it when i turn on the heater from inside the car.
The oil seems fine so i dont think coolant is leaking into it.
Perhaps ill just get a new block? I was actually thinking about doing this even before trying to fix it but it is very hard to find one where I live. lol
Also here are the updated links to the videos from the original post
It is common for the cam cover gasket to fail in that area causing the same symptoms as you have….
I think I would clean off the area as good as possible with the engine cold, then start her up and and look for the leak… I'm not sure if a fuel leak from the intake manifold dripping onto the exhaust manifold would smoke like that or just catch fire….🔥
