golf mk1 convertable
(In Topic #207277)
instrument cluster
Verify that pin 14 black has 12V battery both sides as well as pin 2 (brown) is ground, and that wouldn't hurt to add a ground to frame right there, as well as placing a piece of electrical tape under the mylar. Remove the main connector shroud, carefully lift the mylar, and run one piece of tape over the tongue pad side to tighten up the connectors.
Yes cluster are known to be iffy.
check the dash earth to the side of the head, its the brown/white with a ring terminal
