correct relay diagram for mk1 cabriolet GTI
(In Topic #216233)
Recently purchased a 1988 1.8 GTI cabriolet, and im not sure if my relays are positioned correctly, Heres why.
Carrying out some basic checks before taking it on the road and realised that indicators and hazards are not working. pulled fuse 19 which was blown. Great, Simple fix!! new fuse didnt help. When i turn on hazards or flick on a signal, i get a solid green light on the dash (not sure if this flashes when working properly?
Now ive gone to check the relays and ive found 2 different digrams on the net. One has the signal relay on the far right, and another has it on the one immediately to the left.
Now before this happened, i had a problem with the fuel pump not kicking in, which i solved by wedging the microswitch closed on the relay, but obviously had to pull it quickly when parking back up. problem is, in my attempt to quickly lean over into the passenger footwell, i pulled the wrong relay. not sure which one but it may have been this one and im wondering if ive put it back in the wrong slot?
Can anyone confirm which once is correct?
Thanks in advance.
f4 for the Hazards f19 for the turns.
If the hazards work, that eliminates the turn signal relay.
The hazard switch on the Cabriolet has 2 single Bare wires, and if those are shorting to ground by touching each other or that they are loose in the dash from a re-install gone wrong they can short and blow the fuse.
The Blue/Black have 12v full time, and needs to be heat shrinked so it can't short in the future.
Then the suspect is either the Turns Stalk, and or the Hazard Switch (more likely).
Both fuses are ok. Neither turn signals or hazards working, Ill test the relay tomorrow and look at replacing.
The cars had MOT in november and has been sat in a yard since. ( inclement weather/snow during that time)
If the relay doesn't solve it ill look at the switch.
Thanks again
Its about 3/4 down the page, ignore relay 292 (lights left on buzzer) as that's not a standard relay and not normal there, relay 99 ( intermittent wipers) is normally 19 as standard, the 99 relay is a programmable intermittent wiper so you can change the time between wipes.
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=helllllpppp%2Fhow-to-wire-headlight#post_1583121
Briano1234 said
There are 2 fuses on the system for Turns/hazards.
Ive changed the fuse's and relay. no luck. Before I order the hazard switch, can you confirm that this could still be faulty even if when pressed, it shows a solid green light on the dash?
Is there any way of testing the current hazard switch?
Dave
I suspect that over the years every one of the Mk1's I have seen at the scrappers usually had the hazard switch removed.
a diagram of the hazard so you can see that they use separate fuses and the switch really has two sides.
15, 49 are used when the key is on and the turns are making
49, and 30 are used when the hazard is switched on.
DaveGTIcab said
New hazard switch arrived today, hey presto I now have flashing hazards. However no turn signals
What are they doing? as in glowing? Check your fuses first….the higher number.DaveGTIcab said
You also replaced the relay? You might want to place the old one back in, but if you replaced the switch without disconnecting the battery, then check your higher fuse as in f19 again…. Especially if you didn't heat shrink the bare wires not so much the brown one, but the blue/black as that is hot all the time.
From time to time I have seen issues with a Generic Flasher relay causing this issue WAGNER brand comes to mind.
Last edit: by Briano1234
I wonder if the previous owner ever had indicators?!!!!
Yep, not having the blue/black is the same a a blown f19.
Sorry not to have caught it earlier and saved you some monies.
I hope you insulated that bare green wire….
No need to apologise, the old switch was a bit sticky anyway and this one is much better.
Thanks for all your quick responses.
