Suplemental instrument binnacle
(In Topic #217811)
Wiring question
a supplementary instrument console.
Three gauges:
Volts
Oil temperature
Oil pressure.
Have fitted the console and connected all three.
Volts seems to work ok.
Oil temperature seems ok.
Oil pressure gives readings which I think are way out.
On tick-over 3 bar ( which equates to over 40 psi)
Accelerating - the needle goes up against the stop (which equates to overt 100 psi).
Does the oil pressure gauge have some sort of voltage regulator?
Purchased a twin pole sender marked G and WK
Connected G to the gauge
WK to the oil light on there dash.
The oil light comes on when ignition switched on, flashes, and goes out when engine starts.
Any advice very much appreciated
Thank you
Where have you fitted the sensor?
You could always reverse the leads and see if there is improvement.. I got them on backwards once.
The normal OP on mine is at startup 5bar, as the oil warms it decreases.
