Speedo working, Odometer not working
(In Topic #241386)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/IMG_0971.jpg)
![gregpank in the usergroup ‘Paid Member’ gregpank in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![gregpank in the usergroup ‘Local’ gregpank in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Worked for a while but odo has stopped again (speedo still fine if a little jittery at times).
I think I'll need to do it all again but want to buy a replacement drive cog so i don't ever have this again! I think perhaps the crack in mine has progressed.
(As an aside, I did replace my front wiper motor afterwards which involved moving the speedo cable around a lot to gain access - not sure if this did some damage…?)
Anyone know where to buy a replacement cog or any other advice?
‘81 Golf GTi Mk1 TSR1600 tintop
'90s Chesil Speedster on '70 VW Beetle Chassis
‘14 Golf GTi Mk7
‘14 Golf GTi Mk7
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/zender%20avatar.jpg)
![bacardincoke in the usergroup ‘Old timer’ bacardincoke in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
If so, it's #5 (171 957 821 B) on the schematic linked to below -
https://volkswagen.7zap.com/en/rdw/golf/go/1983-7/9/957-236000/#5
The drives are coloured intentionally, there's a cream coloured one too… each denotes the gearing ratio for your particular application, so stick with the one you originally had.
Before you start to take anything apart, have a good look at how it's attached first, the drive pulls off but there's a little circlip (#6) holding it that can be a pain to remove.
If you lose it, it's not that easy to replace, I believe even new speedo cables don't include them meaning you have to reuse your existing one.
If your drive is failing / cracked, be careful extracting it in case any parts fall into the bell housing.
![](https://img.7zap.com/images/oem/audi/Bilder/007/007236000.png)
I went to look for a pic of it and actually found a helpful post on this very forum (couldn't find it before!):
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=technical%2Felectrics_2%2Fodometer-gear
![](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/horse.png)
![PXL_20211129_184813280.jpg PXL_20211129_184813280.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1638211967/uploads/attachments/61a5217e8b014.jpg)
‘14 Golf GTi Mk7
‘14 Golf GTi Mk7
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/horse.png)
![Volks42 in the usergroup ‘Local’ Volks42 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Odometer Gears - Volkswagen - Mechanical Speedometer
![](https://vwgolfmk1.org.uk/uploads/ocf_avatars/blue.png)
Does anyone in the UK/Europe know of a supplier of a similar part?
I did look on ebay but they're about £50 inc postage - and out of stock anyway…
(I did think about buying an old speedo, taking it apart and getting the gear from that - but no guarantee it won't be an old, cracked gear too.)
‘14 Golf GTi Mk7
‘14 Golf GTi Mk7
https://www.etsy.com/uk/listing/1587855463/1981-mk1-golf-speedometer-gear?gpla=1&gao=1&&utm_source=google&utm_medium=cpc&utm_campaign=shopping_uk_en_gb_e-accessories-other&utm_custom1=_k_CjwKCAiA98WrBhAYEiwA2WvhOt0xndBTWN28IaqH49KWA2JJ5MsSpfClbAYqNTu-UTd9M-8n_uO50RoCChYQAvD_BwE_k_&utm_content=go_12604170127_121302797953_508772765434_aud-1410217292831:pla-295577704042_c__1587855463engb_5302862470&utm_custom2=12604170127&gad_source=1&gclid=CjwKCAiA98WrBhAYEiwA2WvhOt0xndBTWN28IaqH49KWA2JJ5MsSpfClbAYqNTu-UTd9M-8n_uO50RoCChYQAvD_BwE
‘14 Golf GTi Mk7
‘14 Golf GTi Mk7
https://www.ebay.co.uk/itm/285565634626?var=0&mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5338749392&toolid=20006&customid=GB_131090_285565634626.142841610237~1869887761586-g_CjwKCAiA98WrBhAYEiwA2WvhOq-f1EageTmHg89wrwABgte3FRxpuUF7xsouGqfu2atqGxxlOsnu4hoC9Z0QAvD_BwE
‘14 Golf GTi Mk7
‘14 Golf GTi Mk7
