Simple respray goes quite astray....
(In Topic #230975)
To find out what happened the roof i applied paint stripper and really very little happened , i ran into a layer of filler, then paint , and again filler , paint and….more filler…more paint, short story no less than 14 layers in total . I then contacted a company about striping the car with blasting but as the layers were much too thick there would be soo much heat that the panels would all be warped , so the only option is to strip the car by hand with strip and clean discs…
The roof had about 3mm of paint and filler that took about 5 hours to remove , the rear quarters 2.5 hours each , bonnet 4 hours , boors 3 hours, you get the idea.
The metal looks damaged in some pictures from the strip discs but its not , the discs do a really good job , and i have found only a few places buried with filler where a repair is needed. The arch extensions also need work again as i removed filler with the discs
Also I'm refitting the panel that sits between the engine and the scuttle , i removed it years ago to fit dcnf webers to an 8v engine and now want to refit it. It turns out refitting is more work than removal .This panel is not available as a spare part so this has come from a scrap car . I was wondering if its ok to spot weld the side of this panel to the inner wing, I'm a bit concerned about causing a fire inside the inner wing , old sealer etc..and have no access to put it out should this happen .
9A,027,278,02A,mikuni r1 carbs,megajolt 36-1,R1 pump,lc1,02J shifter,9J ats…
Surely to weld the scuttle it's a dash out job for the same reasons?
