Reversing lights - help!
(In Topic #206424)
It has had a 10A fuse in there. First off, is that the correct one? If it is, what else might be causing the problem? I had the clutch replaced last week and some welding done to the bulkhead after the clutch cable pulled through, so might that have had an effect? I really need to sort this asap as the car's MOT runs out this week.
Any suggestions?
Thanks!
Last edit: by TeeTee
Or could just be the 2 pin switch since they metal
Yes 10amp fuse is fine in there
Rev lights does not come under a mot so if don't get fixed in time don't worry
Thanks for the help!
