Rear axle bushes - which ones are recommended?
(In Topic #232660)
so while the axle is out I may as well refurbish it and treat it to new bushes, they look old and starting to crack up, and the beam has surface rust which looks mankey…
what are peoples recommendations please?
I don’t want a harder ride, but I’m not averse to tightening everything up a bit
should I go poly - bush or standard rubber?
or, should I go with a mix of rubber pivot bushes and poly for the inner/outer ARB?
