No power to Fuel Pump
(In Topic #243728)
I have replaced all grounds on the car following the Grounds thread on the forums (https://www.vwvortex.com/threads/ground-effects-and-the-repair-of-your-car.5284503/), no luck, still no power going to the pump.
The pump runs if I hook it up to another battery and 2 wires.
When I turn the key the fuel pump relay clicks for the prime, just no power to the pump. I have checked the yellow/red wire and brown from pump to back of fuse board and all seems fine. Jumped pin 30 and 87 and pump does not run. That would suggest a wiring issue to the pump, but I have visually inspected all wires.
I’m really unsure how to get it going. Do I run 2 new wires from pump to battery to get the thing working? Then splice those wire into the back of the fuse box?
Hope some has some ideas.
Dan
1990 Golf Cabriolet. Australia.
