Fuel system filters x 2???
(In Topic #207426)
I am currently in the process of getting a mk1 cab 1983 gti up and running. Had a good crack at the wknd. I went to drain out the previous fuel, been sat for over 3 years. I managed to get a lot out using the pump by turning the engine over, fuel line at front disconnected. Anyway, I found a leak from around the pump as I did this, traced it to a Bad fuel line. In the process of removing it, I found what looks to be another fuel filter. What is this, do I need it or can I bypass it as it looks rusted to hell. I have a new filter for next to the battery as lines look okay up there.
Any information you can advise greatly appreciated. Sorry still very new to this car, taking my time to get it running again. I seemed to have missed summer, whoops!
Tim
May be you are looking at the accumulator? It's a valve which holds the fuel pressure when you switch the car off so it makes it easier to start again when hot.
Does it look like this?
http://www.ebay.co.uk/itm/MK2-GOLF-Fuel-Pressure-accumulator-Mk1-2-Golf-Corrado-K-Jet-16V-431133441C-/391387812082?hash=item5b208810f2:g:KbcAAOSweuxWTIN-
Because your car is not running it's hard to tell if it's working untill the car is going, there is a little screw at the back and if you undo it there should be NO fuel coming out.
If you remove it you will lose all fuel pressure when you stop the car and it will be a real pig to start again when hot.
As the car has not run for a while I am going to bypass the Accumulator just to get it up and running, and then fit something back in afterwards.
I might bypass the accumulator just to see if I can get it running (After I have checked tank for rust……) as the pump looks nice a new so just trying to get fuel to the injectors to get it to fire I have not actually heard it run, just been told it was fine when he parked it up, and started on an exhaust upgrade and left it……..
Thanks for your help!
To clean it out properly you need to remove it and you do have to drop the rear beam to get enough room to get the tank out.
Pictures, my car is a 1988 cabriolet with a lift pump in the tank, yours may not have this pump?
Top of the tank and fuel pipes.
Tool I use and a hammer to knock the sender around.
Remove pipes and electrical connections
This is as far as you need to knock it around to be able to get the sender out.
And it's all out, be carful of the float as it's on a angle and takes a little wiggling and getting it at the right angle to get it in and out of the tank.
(You may not have a lift pump?)
I've left a magnet in my fuel tank to catch and rusty bit floating about.
I just re-read your original post and saw you have a Cab, the accumulator I have is from a TinTop, I think they are the same on an 83 cab, do you have a pic of yours. I think I also have the later Cab type (slightly smaller) somewhere but will have to have to check.
Last edit: by Timmay Zoom Zoom
ok its the same as the TinTop
I have sent you a PM with my email, if you PM your address I will put it in the Post tomorrow.
