Fuel Pump Relay Issue
(In Topic #241092)
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/fireman.png)
![Paul Mk1 84 GTI in the usergroup ‘Regular’ Paul Mk1 84 GTI in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
I know there are a number of very informative posts here in connection to fuel pump relay issues but i have an issue with mine that's slightly different to them all (i think).
When i bridge the connectors 15 and 87 the pump runs and the car starts and idles. when i switch the car off the pump stops running ….. all good so far however this is not a permanent solution.
When i fit the relay in place it is getting power as i can feel the relay click when the ignition is turned on, but the fuel pump doesn't prime and the car just wont start (it will turn over).
I have a '84 GTI with a '83 fuse box in but its all hooked up as far as i can tell correctly as everything else works other than the Rev counter doesn't work when the car is turned on, but i assumed thats something to do with the relay. I have a new relay with the fuse on the top and have tested the relay with a multi-metre, is this the correct relay?
what do we think it could be and what do i check next.
thanks in advance
I forgot to mention i have aba 2ltr engine that was put in before i bought the car. so no bracket like on the standard engine 1.8 engine.
